Add-on minutes: retroactive? immediately effective? removal?
Hi, just commented on post re purchase of additional minutes for $20. I'm going to do that, hope it takes effect right away, also hope it covers any overage I've inadvertantly incurred. When should I remove it to avoid charges on the next billing cycle?
Photo of Suzanne Duiker Kroon
Posted 3 years ago
Photo of Erwin
Erwin
  • 23,576 Points 20k badge 2x thumb
Hello,
Are you on postpaid or prepaid? Sorry I am a bit confuse about your post.
Photo of Ivan
Ivan, Mobile Master
Looking at the selected products and services (plans & add-ons, billing), I'd assume that they're on postpaid.
yes, I'm on a plan.
Photo of Ivan
Ivan, Mobile Master
It's not retroactive. It takes affect immediately after adding it.
that's too bad. I don't think I'll need it next month, so when do I take it off?
Photo of Ahmad
Ahmad
You should remove on the last day of your billing cycle if you don't want to be billed for it again for the next month
Thanks, Ahmad.
