Add a phone to my plan
  • Updated 2 years ago
I would like to bring my son's phone and add it to my monthly plan. How do I go about this. He has a phone we just need a plan and to add it to my bill
Photo of Crystal Field
Crystal Field
Posted 2 years ago
Photo of Mathieu
Mathieu, Mobile Master
Hi Crystal!
You and your son will have to go over to your nearest Koodo kiosk with his phone. They will ask you for ID to confirm you are in charge of that account. Then, you will be able to add your son as a second line on the same account. He can even port his number to Koodo should he want to keep the same number.
Photo of Goran
Goran, Mobile Master
  • 96,868 Points 50k badge 2x thumb
Do make sure that his phone is unlocked if it isn't already or a Telus phone. Since you mentioned android it's best to use a third party such as sellers on ebay. They will provide instructions what how to do it.
