A guide to bringing your own phone to Koodo
  • 2
  • Doesn't Need an Answer
First, I'd like to thank Koodo for the tool provided to inform potential customers whether their unlocked phone is compatible with Koodo's network:
http://koodomobile.com/en/on/switch2k...
That being said, this does have some drawbacks. You need to know the Canadian carrier carrier the phone was originally locked to. If the phone was factory unlocked, or if it came from outside Canada then you'll need the IMEI #.
If you've already got the phone, then it's easy to look this up. If you're considering buying a phone and don't have all of the information, then you're out of luck.
So, I'd like to provide people with a short guide to bringing unlocked phones to Koodo.
If you're purchasing a phone elsewhere:
1. Make sure that the phone is compatible. Koodo's 3G network requires phones with UMTS-CLR (850 MHz) and UMTS-PCS (1900 MHz) operating bands. These bands will be listed under 3G, UMTS, HSPA, or WCDMA bands/frequencies. A phone having only one of these bands can work, but at greatly reduced coverage so I would only recommend buying a phone with both bands.
2. Make sure that the phone is either unlocked or that it can be unlocked. While most phones can be unlocked, this is not always the case. Specific carriers (Virgin UK, for example) don't provide this information. Even if the phone you're buying can be unlocked on one network, you may be out of luck on another.
3. If you're buying the unlocked phone in person (let's say through Kijiji, for example), pop in your Koodo SIM card to make sure the phone is unlocked. Check the phone's operating frequencies. Like i said in #1, only one of the two frequencies is needed to register on the network, but both are needed for optimal performance.
Photo of Ivan
Ivan, Mobile Master
  • 95,856 Points 50k badge 2x thumb
  • 2
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 197,114 Points 100k badge 2x thumb
When a third party unlocking service unlocks your phone by giving you a code are you saying that they get that code from the provider the phone was originally locked to?
  • 203,868 Points 100k badge 2x thumb
Don't quote me on this but I beleive each carrier has a carrier code and that along wih your IMEI is used in some equation to calculate your unlock code. Eveytime i have unlocked a phone I've been asked to provide the name of the ori-inal carrier.
Photo of Ivan
Ivan, Mobile Master
Each carrier has their own algorithm used to generate device specific unlock codes. Not everyone is forthcoming about these which is why you can't always find an unlock code (it took ATT almost a year to allow Nokia Lumia 900 unlocking IIRC).
Apple maintains a "white list" of IMEIs on their servers. Only phones on this list remain unlocked forever. Your operator submits your IMEI to Apple and you unlock your phone via iTunes.
Photo of Ivan
Ivan, Mobile Master
I must also add that some carriers have recently started to block end-users from modifying or adding APNs. This means that even if you unlock their phone, you will not be able to get mobile data to work.
I've been burned when I bought a T-Mobile US Nokia Lumia 810 to use with Wind Mobile here. Phone worked and I was able to make calls and send SMS but could not get mobile data running.
Fortunately I was able to return the phone. Unfortunately we now have one more dirty practice to deal with.
  • 197,094 Points 100k badge 2x thumb
Not the carrier & not the OS it was Nokia then because I've seen many ppl even on here have the same issue with changing APN that bought their Nokia in Canada. Me & Chad tried to help somebody with the issue a month or so ago.
I believe nokia had to release a software tool to allow uSers apn access
You are correct sir :-)
Photo of Ivan
Ivan, Mobile Master
Again, incorrect.
WP8 supports APN addition: http://www.windowsphone.com/en-ca/how...
And here it is on a Lumia 920:
http://telecom.custhelp.com/app/answe...
And on the Lumia 820:
http://straighttalkwindows.com/nokia-...
And this is what I'm talking about:
http://discussions.nokia.com/t5/Nokia...
Are you saying that Nokia randomly chose to disable this on a phone that's a T-Mo US exclusive? Come on now.
Photo of Ivan
Ivan, Mobile Master
And what Chad's referring to is the old Network Setup app for WP7.5 devices which supposedly made it easier to add APNs (this didn't work half of the time, so I ended up doing manual setup in Europe on my unlocked Lumia 710 at the time).
Photo of Don
Don
  • 6,586 Points 5k badge 2x thumb
The Sonim's Bolt said in its instruction manual that the internet would only work on the bell network, but by configuring the APN, I was able to make it work on Koodo, Telcel (Mexico) and AT&T. I used the infos Koodo and these other companies gave under the configuring "android phone".
Photo of Ivan
Ivan, Mobile Master
  • 95,438 Points 50k badge 2x thumb
What I'm talking about is making sure that the phone has the ability to alter APNs. The Bolt does (despite what the carrier said), but the Lumia 810 doesn't.
Photo of Maharus
Maharus
  • 300 Points 250 badge 2x thumb
Guys, a great place to get unlocking done for cheap is www.cellunlocker.net, they keep prices low and send you the code in a couple hours. I used them and am using my Dell Streak 5 on my koodo plan. Cheers!
  • 195,568 Points 100k badge 2x thumb
I'd rather pay an extra $5-$10 & go with GSM Liberty & get my code withing 15 minutes or so. I've used them twice & had my code within 15 minutes & with a brand new phone I want to he up as fast as possible.
Photo of Ivan
Ivan, Mobile Master
  • 95,796 Points 50k badge 2x thumb
I've used cellunlocker.net and they've always had a fast turnaround time.
Photo of Maharus
Maharus
Thanks ile2010!!
Photo of Ivan
Ivan, Mobile Master
You're welcome.
