A problem sending the command
  • Updated 3 days ago
I am now getting the PowerPoint app message, 'A problem sending this command'. This has only just started.
I'm running IOS 12
Iphone 7
Can anyone advise me of a solution to this. Many Thanks
Photo of jLang
jLang
Posted 1 week ago
Photo of Goran
Goran, Mobile Master
  • 97,450 Points 50k badge 2x thumb
When do you get that error? You might be better off going on Microsoft forums for help. You can try force the app or reinstalling it
Photo of Dennis
Dennis, Mobile Master
  • 196,488 Points 100k badge 2x thumb
Try to uninstall and reinstall the app.
Try to create a new file if possible from the app.
This is Koodo forum, maybe a microsoft office forum will get better answers
Photo of Robert
Robert, Mobile Master
  • 107,280 Points 100k badge 2x thumb
iOs 12 is already out?! Or it's in BETA? That might explain the problem.
Photo of Dennis
Can you update to ios 12 yet @Robert?
I always avoid ios updates so I cant tell
Photo of Robert
Nope, only 11.4.1
Photo of Allan
Allan, Mobile Master
  • 62,624 Points 50k badge 2x thumb
If none of the above work I would try contacting microsoft for app specific support.
https://support.office.com
Photo of DonHart
DonHart
  • 60 Points
Make sure that you’ve updated the Microsoft apps on your iPhone, and try again.
If you continue to experience the issue,you can use Powerpoint fix method.
