!Native Android Problem! after my update Q10 v. 10.2.1.537
Hi,
I made the new update this week on my Q10. The version 10.2.1.537 and it look to broke the native android apps, ... I cannot open any android apps that we can download from the BB world like:
- Skype
- Koodo self-service
- Remember the Milk
- and all others
and it look to not install my FM Radio like the news ?
thanks
Photo of Frédéric Gagnon
Frédéric Gagnon
  • 248 Points 100 badge 2x thumb
  • frustrated, update always busted :(
There's a known issue...
Here's an article
Having issues with your Android Runtime not working after the 10.2.1 update? Read this! http://www.crackberry.com/having-issu...
I don't know the answer to that.
Photo of Erik Mieras
Erik Mieras
z10 and q10 ... same problem on my Z10 with telus
Read this entire thread Erik. If you have a backup restore it and then retry the update. If you don't have a backup you can try using BlackBerry Link to reload the current firmware which may solve your problem.
Erik Mieras
Already fixed it, just side load the new Android runtime, take a 2 minutes, find them at crackberry... then restart device. no backup or reinstall required
Frédéric Gagnon
I resolve it by reloading the update, need to backup before .. :)
http://alturl.com/usvm2
Photo of tshooz
tshooz
  • 2,936 Points 2k badge 2x thumb
Your radio would be in the music app. As for Android apps try deleting them and reinstall. For native BBM apps try a battery pull.
I've been doing some research and it would appear you're just going to have to wait for bb to fix this issue. They are aware of it so you'll just have to be patient. Shouldn't take too long.
Tshooz, the radio app is a feature that only arrived with 10.2.1 it's a new feature.
Frédéric Gagnon
Ok :( thanks.. I didn't find anything good on google too :)
It's always the same.. got different problems on every update on my Q10, others was better :p but the Os 10 Rock lol :)
And I found the fm radio inside my music player :)
I'll post upgrade when I will get some
Photo of tshooz
tshooz
It's ashamed that we are seeing issues with the official release. I think the mass roll out was a bad idea. We didn't see this many for those of us running the leaked version. I believe the Koodo app is native BB app while Skype is an Android port. I hope my signal issue gets resolved soon or I'll be converting back to a leaked version where i had no issues.
Glad you found your FM radio. Unfortunately us Z10 owners can't get it :'(
The rollout is staggered and not a mass roll out. Should be completed by the end of February.
The Koodo App is an Android Port
Frédéric Gagnon
Photo of Sheldon Kerzner
Sheldon Kerzner
  • 60 Points
That article is for BBOS devices, and not for BB10 devices.
Frédéric Gagnon
Don't matter, you CANT make the update again, if you don't do these step! They Keep this method :)
