511-1 Text
I got a text from 511-1
"Koodo:Track your usage w/the Koodo Self Serve app for free! Download @ http://koo.do/SSAPP"
I am worried that would I be charged for any fees... because last time I got text from Ifortune and charged for seven months @10/month
Photo of Paul Gomes
Paul Gomes
Photo of Mo D.
Mo D.
  • 17,268 Points 10k badge 2x thumb
That is a Koodo text. Basically it links you to download the Koodo Self Serve App for your phone. You can do it yourself from your respective App/Play Store if you dont feel comfy clicking it.
The Self Serve app does require wifi/data to operate though.
Photo of Dennis
Dennis, Mobile Master
  • 178,292 Points 100k badge 2x thumb
Plus, you won’t be charged data fees when using the Koodo app, even while traveling abroad with a 4G (HSPA) device
Photo of Jonathan
  • 816 Points 500 badge 2x thumb
You can download the app via wifi and the usage done via your mobile DATA is totally free to download it you can follow the link that was sent to you or:
Go to the device's App Center icon. App Store (iPhone) Android Market(Android) or BlackBerry App World Storefront(BB)
2 Search for Koodo Self Serve app.
3 Select Install and follow the onscreen process.
4 Once the app has been downloaded:
Select the icon to access the Koodo Self Serve app.
Log in using existing koodomobile.com/selfserve username and password,
