4 of us visiting US for 4 days. Need to communicate via text only. Would Pay-per-use roaming be more economical than Easy Roam.
  • Updated 7 months ago
Photo of Julie Wormngton
Julie Wormngton
Posted 8 months ago
Photo of Allan
Allan, Mobile Master
  • 62,724 Points 50k badge 2x thumb
Depends on how many texts you all plan on sending. If a line is sending more than 100 texts * then Easyroam would be cheaper.
Edit: * (/day)
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,676 Points 100k badge 2x thumb
Not exactly. If you're texting every day, easyroam would be $7/day. Pay per use charges $5 for a block of 100 text messages and you get until the end of the billing cycle to use them. Unless you're sending more than 100 a day, pay per use is definitely cheaper for texting alone.
Julie Wormngton
I am assuming that either option is for an individual phone not an account ie all 4 phone no. are under 1 account.
Each line on the account is treated separately as far as billing and roaming is concerned.
Julie Wormngton
Not likely, doing Orlando so just need to keep in touch while we’re out and about.
Photo of Allan
Pay per use rates for texting are $5/100 outgoing texts, free incoming.
Julie Wormngton
So we come do that with airplane mode on?
Photo of Allan
No, airplane mode has to be off. (If it's on then you won't get service). If you only want to send texts than disable data and don't make or receive any calls.
Photo of Dennis
Dennis, Mobile Master
  • 196,652 Points 100k badge 2x thumb
No. Airplane mode needs to be off in order to text. But you should make sure your data is off and data roaming is off too
Julie Wormngton
Oh okay. Thanks for the help! Obviously a travel newb here.
