20mb per day for no reasons
  • Updated 1 month ago
Hi, when i check my data consumption i see that always everyday i have a report that say i used 20.00 mb but all the time that same amountvompiled with the rest can i know what uses it
Photo of Yoan Gagnon Roussel
Yoan Gagnon Roussel
  • 268 Points 250 badge 2x thumb
Posted 1 month ago
Photo of Goran
Goran, Mobile Master
  • 94,240 Points 50k badge 2x thumb
No idea. Koodo won't know either. Sure is specific. You can use a data usage app to analyze your usage to see what uses how much data and when. Android has a pretty robust one built in. Ios however doesn't have a monthly reset option so if you're on iOS and haven't been doing itonthly it won't be of help. But there's are good third party options.
Yoan Gagnon Roussel
Thx for fast reply, gonna check right now :)
Photo of Dinh
Dinh, Mobile Master
  • 37,562 Points 20k badge 2x thumb
@Yoan: 20Mb is a small amount when it comes to images, videos , and syncing services. There would be many possible sources for it like google photos, maps, email sync, dropbox backup... It will be hard to pinpoint. I would try to recall what you did at the time with the phone or observe the data usages/app usagein the next few days regularly to find out which app/service.
