. Will I be charged romaing fees by turning on my phone to receive a call?
  • Updated 1 month ago
I am going on a cruise and when I return I will need to turn on my phone so that the shuttle service can contact me in the morning
Photo of Michelle Boyle
Michelle Boyle
  • 80 Points 75 badge 2x thumb
Posted 1 month ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 199,580 Points 100k badge 2x thumb
If you're not in Canada then yes you will pay roaming fees... If your in Canada then no
Photo of BobTheElectrician
BobTheElectrician
  • 62,064 Points 50k badge 2x thumb
Yes, if your call will be received while you are in a foreign country.
But if you only anticipate one or two calls or texts, you can roam at pay-per-use rather than the $7 or $10 EasyRoam daily rate if that's a concern. Just make sure you have international roaming enabled on your account.
Michelle Boyle
If I enable it don't I automatically get charged the $7 if I get any call at all?  I thought I saw someone say that. I am only going to get one call and will need to have my phone on for about an hour to wait for the call. Am I charged for roaming by the minute?  And how do I know how much I'm charged per call. $7 isn't that much but seems a lot for just one call.
Photo of Allan
Allan, Mobile Master
  • 56,856 Points 50k badge 2x thumb
If you have easy roam on your account then you are charged $7 on the first use (answering or making a call, sending a text, using data) and then can use your canadian plan as normal for 24 hours.
If you dont have easy roam its $0.50/min.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,132 Points 100k badge 2x thumb
If you have easy roam on the account you will be charged $7 for using any minutes or data, or for sending any text messages. If you remove easy roam, you will be charged pay per use rates, which would be $1.50/minute in the U.S.A. The free international fee roaming add on is NOT required to use the phone in the States.
Photo of Dennis
Dennis, Mobile Master
  • 187,616 Points 100k badge 2x thumb
If u don't want to incur roaming fee unnecessarily, make sure you data is off and don't make or take any calls and don't send any texts until you are ready
