[Prepaid] Unable to Receive Any Incoming Call - Nexus 4
Hello everyone,
I am currently using a Nexus 4 running stock Android 5.1.1. I am also on the $15 Unlimited Messaging Base Plan, with an active Talk Booster Add-on and a positive Top-Up balance.
I am unable to receive any incoming calls. I can place outgoing calls just fine, but when others try to call me, they either get "the number cannot be completed as dialed," or "the call cannot be completed due to insufficient balance." As this is my primary phone, this is a big concern.
Any help on this would be greatly appreciated. Thanks!
Photo of William Yang
William Yang
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,574 Points 100k badge 2x thumb
First try power cycling the phone, while the phone is on hold the power button until the phone turns off and back on then let go of the power button. See if that works.
If it doesn't then try turning off the power and removing the SIM Card, then replace it and turn the phone on and see if that worked.
William Yang
Hello Paul,
Thank you for your suggestion!
I've done that a couple times already but gave it a go just right now; no dice.
Photo of BobTheElectrician
BobTheElectrician
  • 67,356 Points 50k badge 2x thumb
Sometimes something as trivial as using the 1 prefix or not when calling out will make a difference. Ask someone to dial you using the 1 and then not using the 1 before your number and see if it makes a difference.
Otherwise, sounds like an account glitch that will have to be fixed by the mothership. *611 in the am.
