<my phone is not allowing me to send my messages? if i call koodo will i be charged for the call?
Photo of Rachelle Mohn
Rachelle Mohn
  • 150 Points 100 badge 2x thumb
Posted 3 years ago
Photo of DarcyLB
DarcyLB
*611 no charge
Rachelle Mohn
I canot even call because it says my mobile network is not available? It must be obvious?
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
was it working before? Did you activate your sim card? We need little more info to help you.
You can contact Koodo at (1-866-995-6636) or 647-788-4337.
They don't charge you for technical support.
Rachelle Mohn
Ok. I will call from public phone. Each rime I try to send a text a message comes up, network is not available.
Photo of Mayumi
Can you make a phone call?
Did you try turn the power off and on?
And/or take the battery and sim out for awhile and put hem back in and turn the power on.
Rachelle Mohn
Motorola G. Not supposed to take out battery and yes I tried turning it off. I may try to remove Sim card though if you think it may work?
Photo of Mayumi
Ok, don't touch the battery if its Moto G.
And removing sim card works most of the time :)
Rachelle Mohn
Is there something in settings I should do?
Rachelle Mohn
Ok. I will try. Thanks for being on touch
Rachelle Mohn
Will I lose photos for removing my Sim card
Photo of Marnie1
Marnie1
  • 306 Points 250 badge 2x thumb
Your pictures are on the phone's internal memory and won't be affected by removing the sim card.
Rachelle Mohn
Could someone from Koodo please call me at my hotel in mexico. The 1-866 # is not working on any pay phone. This is extremely inconvenient! The phone number is 998 272 85 00. Room 421. Why dies it take hours for you to reply?
Rachelle Mohn
I don't even know how to open the phone.
Photo of Lipty L
Lipty L
  • 60 Points
try going into your settings, under more networks, and manually select one of the networks from the country you are in currently. In addition, if you are out of country and trying to dial 1-866-995-6636 you will need to dial out the country code first.
Photo of Khaleila
Khaleila
  • 4,102 Points 4k badge 2x thumb
Hey Rachelle,
The steps Lipty L gave are correct in order for you to try and connect to the network in Mexico. However, to call us you'll have to dial our international number which is 1-647-788-4337 but to not sure if this will work from a payphone. Hope this helps.
________________________
Photo of Mayumi
Hi, Rachelle.
Are you a prepaid customer or postpaid(monthly)?
If you have a prepaid plan , you can't roaming outside Canada. (I thought you are in Canada and having trouble with text,)
