***Just a Comment, Lolipop 5.02 on Moto G. Installed today, no issues, Works Great :)
  • 2
Photo of Spence
Spence
  • 8,354 Points 5k badge 2x thumb
Posted 3 years ago
  • 2
Photo of Peter Lynch
Peter Lynch
Is it 1st gen ?
Peter Lynch
I have moto x 1st gen and moto g 2nd gen waiting for the update :(
Photo of Spence
Spence
Yep, Moto G 1st Gen
its weird because i haven't got any notification and if i do a manual check it keeps saying its up to date on 4.4.4. Am i doing something wrong? My battery was at 73% when i checked and I was connected to my wifi.
Photo of Khaleila
Khaleila
  • 4,102 Points 4k badge 2x thumb
Hey Kuldeep, You need to have the latest Motorola Update Services application to install Lollipop. If this app isn't up to date you will not receive the Android 5.0.2 Lollipop update. Here are the steps to update the app: Tap the Apps icon/Tap Play Store/Tap the Menu button then tap My Apps/Tap Motorola Update Services under “Installed”/Tap Update. Hope this helps.
Peter Lynch
There is no. Moto g 2 update service on play store ,so what now ? Bought Fone at staples and use koodo
Thanks Khaleila, I will try this.
Photo of rikkster
rikkster, Mobile Master
  • 67,084 Points 50k badge 2x thumb
Or you can click the link below:
https://play.google.com/store/apps/de...
Photo of Sparky69
Sparky69
  • 90 Points 75 badge 2x thumb
Working fine here as well. Only thing I really don't like is that there is no longer a useful silent mode with just the LED for notifications.
Photo of Khaleila
Khaleila
Hey Spence,
Great to hear :).
________________________
Photo of Graham MacCara
Graham MacCara
  • 1,242 Points 1k badge 2x thumb
Thanks for posting this. I came on here exactly to find out if I should update or not. Wish me luck.
