"International Data Roaming" vs "Easy roam"?
  • Updated 9 months ago
I will be in Mexico for few days and I would like to be able to make local phone calls. What add-on do I need? Is "International Data Roaming" enough?
What is the difference between "International Data Roaming" and "easy roam"?
Thanks!
Photo of Virginie L.
Virginie L.
  • 80 Points 75 badge 2x thumb
Posted 9 months ago
Photo of Goran
Goran, Mobile Master
  • 97,358 Points 50k badge 2x thumb
International voice roaming and international data roaming. Those enable you to Roam. Default is pay per use rates (it's way too much) or Easy Roam, which I'll explain here as well just in case, which let's you use your phone as normal and draw from your plan for 10 dollars per 24 hours up to 100 dollars per billing cycle.
Virginie L.
Alright. If I just want to be able to make local calls (and not roaming because I'll have access to wifi), what is my best option?
Photo of Goran
Koodo doesn't have VoWiFi / VoIP as an option so you'd either have to get a VoIP service like Fongo where Mexico rates are dirt cheap and you can use via the WiFi you'll have or get a local prepaid sim on the cheap.
Photo of David
David, Mobile Master
  • 93,614 Points 50k badge 2x thumb
You will need a VoIP App such as Fongo or Skype or similar to make phone calls through Wi-Fi.
