$2 data block with picture messaging
  • Updated 6 months ago
We have unlimited talk and text plan with no data. Added on the $2 data block with picture messaging, so we could receive pictures via text. It's not working, no pictures unless you have the data turned on. Galaxy S5, is there other setting changes we need to make in the phone itself?
Photo of marty
marty
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of David
David, Mobile Master
  • 93,564 Points 50k badge 2x thumb
You have to turn data on. The block prevents any other form of data other than MMS data being used by your phone.
Photo of S JW
S JW
  • 92 Points 75 badge 2x thumb
Will this add on block all forms of data such as third party apps like Facebook?
Photo of Sophia
Sophia, Mobile Master
Yes, see Bernard's response below - you won't be able to access anything else.
Photo of Bernard
Bernard, Official Rep
  • 80,864 Points 50k badge 2x thumb
Marty, dfbutt got it right!  Data on your phone still has to be turned on. You won't be able to access anything else but your picture messaging will work.
Photo of Sarah Maye
Sarah Maye
  • 60 Points
Can I still get this $2 add on?
Photo of Mayumi
Mayumi, Mobile Master
  • 115,056 Points 100k badge 2x thumb
Log into self serve > View My Plan > Change my monthly Add-ons > Data Block w/ Pic Msg
Photo of marty
marty
Thanks dfbutt and Bernard for the quick replies.
So, my daughter had a samsung and now has an iphone which uses data up like crazy. She has her data (1GB with our plan) off most of the time but cannot receive pictures via text unless she turns it back on - which is a pain turning off and on to control her data usage. If i add the Data Block to her plan, will she still be able to access apps and internet as long as she is connected to wifi? Just trying to figure out if this add on is a benefit or not to help her control her data usage. Thanks!
Photo of Dinh
Dinh, Mobile Master
  • 41,784 Points 20k badge 2x thumb
Hi Heather,
Yes, if you have the data block on, you still can access data through wifi. The data block duty is to block data from Koodo but allowing MMS passing through.
However, as you mentioned, your daughter plan has 1GB of data. If you put the block on, you won't be able to access that 1GB of mobile data.
Photo of Erwin
Erwin
  • 23,576 Points 20k badge 2x thumb
Hi Heather,
There is an option to prevent your daughter from adding additional data once she hits her limit. I can’t seem to find this in self-serve but you can call in or visit a Koodo shop to add this in. The only disadvantage is that your daughter wont get sms if she hits 50%, 90%, 95% of her data.
Photo of David
She can also go to settings in her phone, and determine which apps can access cellular data, go to Facebook and turn off auto play video ( a big data consumer), make sure Wi-Fi assist is turned off, in addition to being more judicious with her data use generally.
