$15 base plan and $20 data add on
I am going to buy a prepaid sim card with base plan $15 and $20 data add on. Is this combination gonna work when I am traveling to Calgary? Or I need to buy the canada wide base plan? Thanks
Photo of Tse Pui Wah Phoebe
Tse Pui Wah Phoebe
  • 102 Points 100 badge 2x thumb
Posted 3 years ago
Photo of BobTheElectrician
BobTheElectrician
  • 61,918 Points 50k badge 2x thumb
$15 base plan only gives you texting. If you want to talk at all, you will need a Canada-Wide Talk Booster add-on or upgrade to another base plan that includes voice minutes as well. Your data add-on will work Canada-wide.
Tse Pui Wah Phoebe
Thanks. So $25 base plan Will do? Both test n talk in Vancouver and Calgary ?
BobTheElectrician
These plans can be very confusing:
$15 base + any booster for anytime minutes covers you coast to coast for voice. Minutes never expire as long as your base plan is kept up to date. You can adjust the number of minutes you want to buy, and they are valid anywhere in Canada.
$25 base plan only gives you evening and weekends local calling - no long distance.
Data booster is good coast to coast.
https://www.koodomobile.com/prepaid-plans
