Will unlocked iPhone 6 work for Koodo?
Bought this iPhone 6 unlocked from the Apple store. Have been using it on Fido. Will it work on Koodo network?
Yes it will work then. To be safe and for a other phones, use willmyphonework.net
Did you bought it unlocked from Apple.ca online, then it should work.
If you bought it from a Canadian Apple Retain store then I would double check that the phone is actually unlocked by trying another SIM card in it
Hey Rebeca,
Your iPhone should work if you purchased it carrier-free from Apple 🙂
