Will my Telus iPhone 6 work with Koodo ? Is it 100% guarantee that it will work?
Yes.
BUT. It does have to be unlocked to work with Koodo. But YES overall.
Actually, Jeff it doesn't need to be unlocked to work on Telus. That's why David said yes. Telus/Koodo iPhone 4/4S/5/5C/5S/6/6+ are all compatible with the others network
Ya that is what my question was. Will a telus locked iPhone 6 work with koodo without unlocking?
Again, yes.
I can confirm, yes! Will even work with public mobile!
As a former Public Mobile employee, I warn you that it WILL NOT work. You must get it unlocked first. And iPhones do not work with PM data services. The limitation being that you cannot add the PM APN to the phone. Know this before proceeding with Public Mobile!
Not Jeff wrote:
As a former Public Mobile employee, I warn you that it WILL NOT work. You must get it unlocked fi...
Telus/Koodo iPhones [b][i]***WILL***[i] work with Public Mobile without unlocking, Not Jeff.  The issue currently is MMS which Apple needs to fix in their end.  The data part can easily be fixed by adding a new APN that is identical to that of PC Mobile (sp.mb.com).  And the newer Public SIMs are already provisioned with the correct APN for data use. In fact, when I tried my Public SIM in my MotoG, data even worked with my Koodo APN (which was selected by default).
Hey peeps, why not go to a Koodo store and try the SIM? Easy-free and if it doesn't work, then return the phone back to Telus. Best way to be sure it works!
Userlevel 3
I use my TELUS iPhone 6 on Koodo right now. Works just fine and its not unlocked. iPhone 5s worked fine aswell also locked to TELUS. So yes it will work.
Cameron wrote:
I use my TELUS iPhone 6 on Koodo right now. Works just fine and its not unlocked. iPhone 5s worke...
Did you have to change any settings for it to work on Koodo?
My 5s originally with Telus isn't connecting to the Koodo network
I wasn on Telus and switched to Koodo. And it worked without unlocking. .. so, yes Telus phone will work on Koodo
