will my iphone 4 with koodo will work with prepaid?
  • 15 June 2015
  • 7 replies
  • 26 views
(empty)
Yes, if it is either unlocked or locked to Telus/Koodo.
Yes, if it is either unlocked or locked to Telus/Koodo.so it should work with a iphone from koodo then?
Yes, if it is either unlocked or locked to Telus/Koodo.You can't get more genuine than gear bought from Koodo. If you are switching from monthly to prepaid, it will go very smoothly. One last bill from monthly (prorated, by the way, no "penalty" for cancelling + balance of tab (if any).
Prepaid SIM only available from boutiques or ebay.ca. $20 charge credited back on activation. 10% discount on monthly base plan if you register a credit card for auto top-up.
Go for it!
Yes, if it is either unlocked or locked to Telus/Koodo.i already am on prepaid the iphone 4 is from my aunt!
If it's unlocked it'll work no problem.
so it will work if its a iphone 4 from koodo right....
I'm not sure if they do that or not, you have to give them a call and see if they still do that I=or if they ever did...I think that it will work...
