Will Iphone 5c work from USA plan?
I am getting a phone from my family which are in the united states, and their carrier is Verison. Due to a promotion we can get the Iphone at a cheap cost there. Will the Iphone work will koodo? Verison has not really given us a clear answer, only stating that they have a SIM which works for 4g. Does anyone have knowledge of if an unlocked iphone 5c from verison would be able to work on Koodo? Or if there are other ways to make this work?
Userlevel 4
If, by some method, you are able to get the IMEI of the phone, put that number in the empty box contained in the link below. That will tell you for sure. http://koodomobile.com/en/on/switch2koodo-step-1-c.shtml
Verizon appears to operate on 800/850/1900MHz frequencies. That lines up with Koodo so it looks like it will work. The IMEI would help confirm. http://www.ehow.com/facts_7612240_mhz-range-verizon.html
Just make sure the phone is unlocked first
