Will I be charge using facetme & games in my iphone?
Userlevel 2
Facetime uses data to run, just like skype, facebook, twitter and so on. if you run Facetime over cellular data it might consume your data package really quick. You might like to do it over wifi (hassle free). Some games now use data. As long as you download free games from itunes you will be alright. What type of plan do you have?
Xavier wrote:
Facetime uses data to run, just like skype, facebook, twitter and so on. if you run Facetime ove...
Even Free games may use data Xavier. If this is something you're worried about Rosario, Check out pauls suggestion. That way if you Move away from your wifi source, your phone won't switch to Cell Data and start using your allotment
Userlevel 2
Free games can use data because of the ads that are running in the app.
Facetime uses data and so does downloading games from the app store. Some games use data while using the game for scoring features against friends and others on social sites like Facebook ect. If your worried about it or dont know what games use data while playing turn off data and some games wont work or show that you need data on for certain features.
