Will an Iphone 5 locked to telus work with koodo
9 times out of 10 yes it will. Best to try it at a Koodo booth before you either sign up, or buy that phone. Also depending on which phone you have now, you may need to go and get a new SIM card. Im not 100% sure the size of the Iphone5 SIM but i think microSIM.
Chadwick wrote:
9 times out of 10 yes it will. Best to try it at a Koodo booth before you either sign up, or buy ...
You may need to plug into itunes to restore on the 1 out of 10 times to get it work
The iphone5 uses a nano-sim FYI.
