Will an iPhone 5 from Koodo work with Telus?
Hi there I got a certified pre-owned Koodo device iPhone 5 16GB as a.gift. Will it work on the TELUS network as well or do you I have to get it unlocked from Koodo first? Thanks, T
iPhones (4 and up) from Koodo and Telus work on each other's network. Just insert the sim card. If it doesn't work you have to update the carrier settings first as show here: http://help.koodomobile.com/plans-add-ons-data-and-other-services/iphone/how-do-i-activate-my-iphone
Great thanks!
