Will a Verizon iPhone 6s plus that is factory unlocked work with Koodo?
As titled, this phone is factory unlocked from Verizon, and the seller listed the phone as "This Apple smartphone supports GSM/EDGE 850/900/1800/1900 CDMA EV-DO Rev. A and Rev. B 800/1700/1900/2100 UMTS/HSPA+/DC-HSDPA 850/900/1700/1900/2100 TD-SCDMA 1900/2000 FDD-LTE 1/2/3/4/5/7/8/13/17/19/20/25/26/28/29 TD-LTE 38/39/40/41 and 4G networks."
I'm thinking that it would work since it has FDD-LTE band 4 (this is the AWS band right?) but I'm not sure. And I also don't know if it being a Verizon phone originally would post limitations.
Thanks in advance for your help!
Userlevel 2
If it's unlocked, it is compatible with Koodo. The unlocked iPhone 6s plus (USA version) works with almost all kinds of prevailing networks (quan wang tong).
Hello.
In order to see if the phone will work with Koodo you have 2 options
1) Type your IMEI # into the spot on this Koodo webpage to see if it will work. : http://help.koodomobile.com/getting-started-with-koodo/sim-cards-and-non-koodo-phones/how-do-i-know-...
2) Or check compatibility here : http://www.willmyphonework.net
Userlevel 2
Robert wrote:
Hello.
1) Type your IMEI #...
The first link is practical. Some information on willmyphonework is incorrect.
You may not be able to roam in the US with a Verizon phone. Their phones have unlocked SIM slots for international use but I believe that the phone defaults to CDMA mode when in the US.
