why incoming calls going straight to voicemail
Traveling in Canada with iPhone 5. Why Incoming calls going straight to voicemail
Hello Sandra,
Do you have do not disturb mode activated (little moon in status bar)?
Robert wrote:
Hello Sandra,
No. Assume not activated as Manual button off
Robert wrote:
Hello Sandra,
Are you a new customer?
Were you able to receive incoming calls before?
Robert wrote:
Hello Sandra,
Yes.
Robert wrote:
Hello Sandra,
So you're a new customer and the calls worked before? Yes is the answer to both quesitions?
Robert wrote:
Hello Sandra,
Not new customer. Incoming calls worked before. Am travelling this week so need to get calls.
Robert wrote:
Hello Sandra,
You're travelling in Canada or outside? I'D say in Canada, but want to make sure...Ddi you try restarting your phone?
Robert wrote:
Hello Sandra,
If Robert's suggestion doesnt work, try Settings>General>Reset>Reset Network settings
Warning, any wifi passwords will be lost
Robert wrote:
Hello Sandra,
Also make sure your phone app is not restricted to "only people in my contacts"
Robert wrote:
Hello Sandra,
Good idea. Checked. Not restricted.
Are you able to call out or text successfully?
Yes
Sandra Annesley wrote:
Yes
Have you tried Robert's suggestion above?
Yes
Yes. Was fiddling with Fitbit settings yesterday. Turned off automatic Time Zone setting to force time to set to ET. Could that have affect?
Yes
The time shouldnt have an effect here.
Do you have bluetooth on?  If you do, does it work when you turn it off?
Yes
Works when turned off and when turned on. Now getting incoming calls. Now don't know what changes I made to get incoming calls, and stop going directly to voicemail! Thanks to all for advice!
Yes
Sometimes just turning the phone off then on again fixes things!
Yes
Another sensible idea. Thanks
