What is the difference between the old $55 plan and $94 plan
To start off I have an iPhone. You seem to get the same plan for the old $55 and $94 plans. You get 5GB of data, unlimited Canada wide minutes, unlimited texting and a few other features. But the features I mentioned are the ones I am looking at the most. It just seems odd for these two plans to have such similar features and be so big in price difference. Does anyone know why?
what province are you in?
Sask
I dont see a $94 plan for Sask.
The 5GB plan with unlimited calling in Sask.  is only $48
Make sure you Select SK at the top right of the page.
In the rest of Canada that plan costs 90$. But in sask it costs 48$ even on the tab large. Do as spence said and check the region your site displays. Because in SK, for 48$ a month you get unlimited everything nationwide and 5gb of data.
The $48 is the new plan. If you have an old plan you either have to stick to the old plan or pay off your tab first.
