what add on do I need to not get roaming charges
I am going to Mexico- my flight goes from Toronto, Atlanta, Mexico city. I want to be able to text pictures when both in Atlanta and in Mexico. No need to call - what add on would you suggest.
My current plan is CAN Data 300MB 300 min $40
Are you on a Monthly plan or a pre paid account?
For International texting plans. there is one for $15 75 outgoing texts Free incoming texts Also there is one for $40 50 minutes 50MB of data 50 outgoing texts Free incoming texts
For U.S texts(atlanta) there is **3 days** $10 Unlimited outgoing texts Free incoming texts **10 days** $15 Unlimited outgoing texts Free incoming texts **30 days** $20 Unlimited outgoing texts Free incoming texts
If you want to text pictures you will need Data which you will get data roaming charges for
30 days $40 50 minutes 50MB of data 50 outgoing texts Free incoming texts This is the International data,minutes and text package, Which includes MMS messaging
My plan currently has 300mb of data am I able to use that for MMS messaging from Mexico or does it need to be a separate international data
Miryam Giguere wrote:
My plan currently has 300mb of data am I able to use that for MMS messaging from Mexico or does i...
No. You won't be able. You need an add on for that to work
It needs to be separate. You will need to add the International Data to be able to use it internationally without being charged astronomical overages. My best piece of advice, Call them in the morning when they open, explain EXACTLY what you plan on doing, EXACTLY where your going, and they should be able to put that package on for you.
Chadwick wrote:
It needs to be separate. You will need to add the International Data to be able to use it interna...
Hello Chad. It would be appreciated to have one post with all the information in it. Thanks!!
My apologies Robert, Ill be sure to do my best to get it all in one box next time! sorry about that
No problem. We're all here to learn. The poor lady received 1 e-mail for each one of your post 😛
Hey Miryam,
Do you still need hep with our roaming add-ons?
Please let us know.
Thanks
No it had all been figured out thanks to your help.
