Water Damaged
I was wondering how much will I pay for water damaged if I got no AppleCare?
Hi Jeff, It all depends what sort of damage is done to it and what phone it is. You can always send it out for repairs, they will call you with a quote to fix it (or tell you if its not fixable) and you can decide from there what you want to do, fix it or get a new one. If you went for a swim with it for example, then your best option will probably be to buy a new one.
Userlevel 4
Unfortunately no one covers water damage. I would suggest putting it in a bag of rice and wait a few days or your going to have to buy a new phone.
Userlevel 3
Last time I checked, it was between $300-$400 for an out of warranty replacement from Apple.
