Visual Voicemail not working on Iphone?
  • 10 August 2013
  • 64 views
I signed up for Visual Voicemail for iphone, but cannot get it working. I have called Tech Support, and they say everything is provisioned correctly, but still can't get it to work, and they have opened a ticket. Has anyone else had this issue, and found a fix?
I had same with Telus I took off my phone cause of it was 5.00 a month I wasted basicly
Your cellular data should be on.
Did you restart the iphone after enabling it?
You also typically need to update your carrier settings through itunes after adding the feature.
I do not think you need iTunes for that. You can follow these steps: http://support.apple.com/kb/HT1970?viewlocale=en_US.
