using local SIM card while travelling (on unlocked phone)
  • 10 May 2016
  • 1 reply
  • 367 views
Hi! I am travelling so South Africa soon. I have an unlocked phone, purchased from the Apple Store. If I replace the Koodo SIM card with the local one, I am guaranteed to not be charged roaming fees correct? I will need to stay connected whilst travelling and our partner organization suggested this. Thanks!
Best answer by David AKU 10 May 2016, 20:57
If you remove the Koodo SIM before leaving Canada, then you can be assured of no roaming charges from Koodo.
1 reply
