Upgraded my plan to 5gb but now my data won't work
  • 22 July 2015
  • 54 views
I just changed my plan because I kept going over my data. Now that the change has gone through I have 5 GB of data but nothing that uses data will work on my I phone 6. I didn't receive a message saying my data is blocked, my data is turned on but still nothing
Are you sure data is enabled in your phone settings? Did it work before ?
It was working fine before, and I went through my phone data is enabled. That's why I'm so confused
It was working fine before, and I went through my phone data is enabled. That's why I'm so confused Try a restart
It was working fine before, and I went through my phone data is enabled. That's why I'm so confused Should have thought of that, it's working now thank you!
It was working fine before, and I went through my phone data is enabled. That's why I'm so confused Perfect. You're welcome
