unlocked iphone and lightweight 45$ plan
If I buy an unlocked iphone 6 from apple store, i can still use it with koodo right? i am planning to take 45$ plan (light weight) Thanks,
Yes you certainly can. Just go into a Koodo store with your iPhone 6 and they'll set you up 🙂 Make sure to bring two pieces of government issued ID, one being a photo ID.
Userlevel 2
If it's a new activation with koodo you will b able to get that plan, if you are an existing customer you will have to call into customer support and see if they can help you change the plan
Thank you all for the quick replies.. i will get 10% discount in the monthly bill also right?
I believe the discounts have been removed now that they offer lower prices.
