unlimited incoming calls
  • 3 April 2013
  • 1 reply
  • 12 views
Hi I'm new in Canada an just purchased a koodo prepaid sim for my Iphone. I just moments ago topped up online I wasn't aware that I will have to pay for incoming calls, I chose the $25 base plan but didnt realise that I could chose the 35 for unlimited incoming calls... I want to change it to the $35 an I will pay the extra $10 but I'm not sure on how to go about it. Plz help
Best answer by Camilo_A 3 April 2013, 18:50
Hi there Ruby... I will suggest you to get a minutes booster for the rest of the month because if you want to change to the 35$ base plan, you will lose the 25$ one and you will have to put 35$ on your account to be able to get this plan... Just by adding 10$ will not be good to jump into the 35$ base plan... Those 10$ will be good for 100 minutes... Then when the 25$ base plan expires and you are due to renew, then you can choose the 35$...
1 reply
