total amount to pay for an iphone 5s
hi! i'm planning to get an iphone 5s with medium tab i just wanna know what the total amount will be including taxes. thanks
if you have a tab balance of 0 on your tab then the iPhone 5s will be 425 on medium tab otherwise it would be the medium tab - the amount you owe. I can't really speak for the taxes since they vary from province? You could do a rough estimate though 🙂
Hi there, Daniel is right! However, if you already have a Tab, you'll have to pay it off first and then you'll be able to get the iPhone with the Tab M. Don't forget that there is a $5 fee per month with the Tab M and your plan must be a minimum of $30. Thank you! ________________________ If you see a good answer, give it a star.
