To use the data on our US add on do we need to use "roaming data"?
Hey Laura, In order to use data, whether you have the add-on or not, you must enable data roaming on your phone 🙂 Hope that helps
I don't have to have data roaming on in Canada, I've never had it turned on before. I don't want to get double dinged by koodo
You need Data roaming on in the US because it is not connected to Koodo and the US Data add-on will cover the cost.
You do not need Data roaming on in Canada.
