Tips on how to save data/not go over
I have 10 gigs of data per month. I don't have wifi at home or work. Although I have a lot, I still go over. Is there anything I can turn off? Or any tips on saving data per month. Thanks.
Best answer by Sophia 6 November 2016, 22:55
How old is your current plan, Jill? If you are on one of the newer shock free plans, all you have to do is activate shock free and you won't ever go over your data.
1 reply
