thinking of Switching my plan
I've been a satisfied customer for over a year now, However i've noticed Fido has a very similair plan to mine for about 30$ cheaper a month are you willing to improve my plan to keep me as a customer?
Koodo doesn't have retention plan pricing. I do find it hard to believe that Fido has a plan that's $30 less for the same thing. Are you sure that this plan is offered in your province? Koodo's pricing is very similar to Fido's.
Userlevel 3
There is now way in hell Fido has a plan for the same thing that is $30 less! We would all switch then. Guaranteed Koodo has a plan just like that if not better. What is it that you are looking at Fido?
I can echo what everyone has said, Fido's plans are usually almost identical to Koodo's offerings. If they were indeed cheaper I could understand maybe $1-2 but definitely not $30. As Ivan said, are you looking at a regional specific plan?
It could be region specific or the OP has a Tab plus plan and they were looking at BYOD pricing with Fido. Otherwise the plans are very similar.
Hi Joel,
Can you screen cap it, kinda curious what that plan is.
