Texts not deliverable. Some are on koodo some are not! Help!?
Texts not deliverable. Some are on koodomsome are not, happens even to numbers on my own plan! This is ridiculas, there are enough bars showing, no problems with Internet not that that should mater.
Hello Alicia. Have you tried restarting your phone to see if it it solves the problem? Did you see if this happens to people who had an iPhone only or all the phones?
Robert wrote:
Hello Alicia. Have you tried restarting your phone to see if it it solves the problem? Did you se...
Multiple types of phones, have turned off... Restart?
Hi Alicia,
Are the texts that are not deliverable blue? This is due to iMessages. It's the Apple method of sending texts through a data connection to other Apple devices. If you want to keep using iMessages, you must have data. If not, you can disable them in your settings.
Mathieu wrote:
Hi Alicia,
Are the texts that are not deliverable blue? This is due to iMessages. It's the Apple...
They are green
