Telus iPhone 4 stuck on silent
  • 28 September 2014
  • 2 replies
  • 44 views
My mom's iPhone 4 has been having issues with having no sound when receiving a phone call or text messages. Going through the settings, everything seems to be the way it should be, what could be causing it not to make any sound? Checked sound, and nothing is turned on in Do Not Disturb. Just wondering where to go from there. Thanks for your time.
Hi Daniel, I found a workaround that might work. I'm not near an iPhone to verify, so I can't confirm whether this will work or not. See Jodray's fix. https://discussions.apple.com/thread/4589234?start=0&tstart=0
Hi Daniel, I found a workaround that might work. I'm not near an iPhone to verify, so I can't...Tested, and solution worked, thanks Rikkster! 🙂
