SIM CARD INFO
Ok I checked Amazon out they got cards available I need to know what kind they take for % C I phone thanks some of the cards come with 20.00
here the link if info is needed: https://www.amazon.ca/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=koodo+sim+card
I phone 5C that was sorry.
AFAIK, you need the nano sim.
Be aware that the $20 credit or voucher only applies to new activations regardless of whether you obtain the SIM from a third party or from Koodo directly.
Be aware that the $20 credit or voucher only applies to new activ...
How do you know do U work for them??
U are confusing me please explain:
yes it will be a new number I hope thats what u meant when gotten from the seller but it dont say how much air time on it.
Sim card is to access to the network.
If you activate your prepaid sim card at the first time, you will get $20 credit. So you can use it towards a base plan or Booster.
How much airtime is depends on your base plan.
thanks as said when gotten I will be getting new number but prob prob need 45.00 to cover the unlocking of the I phone 5C they said about 60.00 with tax or prob need 40.00 - the 20 0n it when active.
thanks as said when gotten I will be getting new number but prob prob need 45.00 to cover the unl...I'm not sure I understand you...
Who said $45 to unlocking, or what is $60 for...?
thanks as said when gotten I will be getting new number but prob prob need 45.00 to cover the unl...I was told by customer service I will need about 55$ or 60 to cover the sim card and the unlocking for the I phone 5C and when boughten there will be no air time for me. so if I get the sim card off of Amazon I assume I need 45.00 more to get done. They can not unlock unless I have an active prepaid line or post paid witch I am not approved for.
thanks as said when gotten I will be getting new number but prob prob need 45.00 to cover the unl...Is your iPhone 5c locked to Koodo?
If so, $20 for sim card and $35 for unlocking fee = $55.
But if your iPhone is not from Koodo, they can't unlock it for you. You have to ask your friend/seller to unlock it first.
Add: And again, if you activate your prepaid account at the first time(not phone upgrade), it comes with $20 credit which you can buy talk booster.
thanks as said when gotten I will be getting new number but prob prob need 45.00 to cover the unl...yes the seller  told me she is done the contract for koodo.  and got a I phone 5 S so i am interested in getting this
thanks as said when gotten I will be getting new number but prob prob need 45.00 to cover the unl...for the 5 C.
thanks as said when gotten I will be getting new number but prob prob need 45.00 to cover the unl...So, it's a Koodo iPhone, right?
Then all you have to do is to get a Nano prepaid sim Card. Then you can unlock your phone later if you want.
thanks as said when gotten I will be getting new number but prob prob need 45.00 to cover the unl...Yes my friend the 5C is koodo and locked to them she just got done the contract and renewed it for a 5 S so she asked if I wanted it to buy I looked at it and said yes anyhow thank you.
