Sim card does not coonect to mobile network
  • 2 November 2015
  • 1 reply
  • 55 views
I just unlocked my sim card on my phone and on the website it says all done, but on my phone it says no mobile network found and it also says I have no data although I bought it. What can I do to fix that?
Best answer by Ahmad 2 November 2015, 03:15
What phone are you using? It is an unlocked phone or is it a Koodo phone? Unlocking a sim card is not the same as unlocking a phone. Did you mean to say you unlocked the phone? If so, how did it unlock it? And where did you get your code?
Can you be a little more specific, with more details so we can help you out?
1 reply
