setting up phone
how do I set up phone on prepaid? bought s5 off someone. its with koodo.  local store says cant do that with koodo. your site says you can?
You need to purchase a prepaid SIM (make sure that it's for prepaid, it's different for monthly plans) from a Koodo location or an authorized agent:
https://www.koodomobile.com/find-nearest-store
You can then activate the account and SIM using Koodo's website (Self Serve > Prepaid > Activate).
we were in the store 2 days ago and they said they don't sell prepaid sims. said you have to do a monthly plan.  can you buy one online and have it sent? its for my son and we don't want to do a monthly plan
Michelle Donovan wrote:
we were in the store 2 days ago and they said they don't sell prepaid sims. said you have to do a...
Was it an actual Koodo kiosk or a retailer that sells cell service for various providers like a Walmart or best buy? If you have a koodo kiosk near you then they should all prepaid SIM cards.
it was best buy. is there a kiosk in Sydney ns where we can get it?
There is a 'Stores' link at the bottom of this page where you can find the closest retailer.
