Saving credentials for Koodo self serve shortcut
  • 4 January 2019
  • 4 replies
  • 92 views
So I added a Safari shortcut on my home screen to access Koodo’s self serve site to monitor usage and so on.
The problem is is that it won’t save my credentials. Every time I need to enter my email and password. Very annoying doing this multiple times per day. Is there ANY way to have the credentials saved?
thanks.
Best answer by Mats 4 January 2019, 20:12
I've never used Safari but it should be possible. See if the link below helps.
https://www.techwalla.com/articles/how-to-manage-passwords-with-safari
https://m.wikihow.com/Save-Your-Name-and-Passwords-for-Safari-on-an-iPhone
Thanks Mats!
That helped a lot. I used the iOS password manager to enter credentials and it now fills them in on Koodo’s site after authenticating with Face ID. Not seamless as I still need to tap a couple of times to log in but no longer need to type credentials over and over.
Thanks again!
@Ddsdude the iOS password manager may be okay, but you might want to look at alternatives--particular if you use multiple platforms--maybe you have a Windows PC at home or work, sometimes use Chrome instead of Safari on your Mac (if you have one), etc. There are several excellent cross-platform cloud-synced password managers out there. I've used LastPass for years, though I know many iPhone users prefer 1Password.
Maybe have a look at these as starting points, if you're interested in learning more:
https://ios.gadgethacks.com/news/why-you-still-shouldnt-use-icloud-keychain-store-your-passwords-ios-12-0187009/
https://blog.lastpass.com/2018/09/get-in-app-autofill-with-lastpass-ios-12.html/
And some comparisons of the options out there:
https://www.tomsguide.com/us/best-password-managers,review-3785.html
https://www.cloudwards.net/best-password-manager-for-ios/
https://ios.gadgethacks.com/how-to/4-best-password-managers-for-iphone-ipad-0182337/
Awesome thank you!
The built in password manager in iOS does the job in this case but I’ll definitely look at the third party options for other things.
