rogers to koodo keep my number and iphone 4
  • 20 September 2013
  • 4 replies
  • 79 views
i want to switch from rogers to koodo, want to keep my number and iphone 4, should Koodo will unlock my iphone 4 or I have to go to some other party.
Hi there Amer... If your iPhone is a Rogers iPhone, then you should talk to Rogers to get your iPhone unlocked or you can use a third party service like www.gsmliberty.net... Make sure you account is active with Rogers when you will be porting the number to Koodo, and have handy your account number, PIN number or IMEI of your phone at the moment of activation, this will be needed to port in the number to Koodo... Welcome!
Hi there Amer... If your iPhone is a Rogers iPhone, then you should talk to Rogers to get your iP...Unlocking through Rogers will be the cheaper option if possible. It would cost $100 through a third party.
Yes,You can do it, If you want to change another network but keeping same number means,First you...Spam.
