Were they data charges you incurred? If yes, we had a similar situation last year. Turns out that just because you are connected to wi-fi, if the signal is weak, all phones will try to connect to a network. If you had it on airplane mode it would be impossible.
Enter your username or e-mail address to receive an e-mail with instructions to reset your password.
