Replace Lost Phone with Koodo?
I lost my phone, but my tab is paid off. Can I add a new phone to my plan and add it to my tab or do I need to buy a new one? I had the iphone 4
Best answer by Justin 1 May 2015, 00:52
You can do either ifyou wish. The only thing is the TAB System has changed. For a large subsidy ($500) you may have to change your plan to a more expensive TAB Plus plan if you want a iPhone, and pay a additional $21 a month. May be better to buy from apple directly, but if you have a positive TAB balance you can use it towards your phone if you buy from KOODO
1 reply
Userlevel 4
