Recurring SMS send/receive problems
I never had any problems with Koodo till a few months ago. Now I frequently cannot send texts. It starts to send, the sending bar gets almost to the end, and then it tells me "message not delivered" (discreetly, with no notification). It is going on right now, for the last half hour. Last time that I noticed was Friday Feb 28. When the problem is over, I get a bunch of texts in one go. This is not only annoying but means I cannot stay in touch with my child. That would make me change networks.
Try resetting your network settings. Settings>General>Reset>Reset Network Settings
Thanks! That worked! But what is the problem exactly?
Sometimes a reset is needed. Even the iPhone lol
