problems
My+phone is acting weird. Off and on today it says no service. I cant even use it?
Try Settings>General>Reset>Reset Network Settings Try Settings>Carrier>Turn Off Automatic and try to select Koodo Make sure 3G is on Try a hard reboot by pressing and holding the Power and Home button until you see the Apple logo (about 10-15 seconds) If none of those work then we will need more info.
If the Phone has a Sim card then try removing the Sim card and then rebooting the Phone
What iPhone do you have? Maybe your phone is getting old and a restore would be necessary in order to refresh it up a little bit!
