Problem with outgoing call
I'm unable to place an outgoing call. I have no problem calling out or sending a text. Tom
Which phone do you have Thomas? Have you tried turning airplane mode off and then on again? Try turning your phone off, remove and replace the SIM Card, and then turn phone on and see if that fixes your issue.
I'm a little confused... Can you make a call or not?
Good catch Mayumi. I completely missed that mistake.
It will be different answer if he can't make a call or receive a call. 🙂
