Previous incoming calls over 30 days ago
How do I check previous incoming calls over 30 days ago? When I click on previous usage history, it only goes back to the last 30 days. What if I want to check in the past 60 days?
You would need to click this :
When I click on the previous usage link, I only see up to the last 30 days. My question is: how do I view usage over 30 days ago?
Ccs Csk wrote:
When I click on the previous usage link, I only see up to the last 30 days. My question is: how ...
Oui c'est possible
Look at your bills. They are in pdf format under billing. They go back 18 months and show detailed usage.
Comment faire pour la langue detecter traduction en français
Comment faire pour avoir la langue detecter traduction en français
Voir la page en anglais, cocher sur Francais en bas de la page, au extrème gauche.
You would need to clic on the PDF of the corresponding month. Then you'll see the detailed usage!
Found it, thank you!
