Prepaid iPhone 5s picture messaging not working
I have and iPhone 5s and my base plan says I get unlimited text and picture messaging. I also have a data booster but the picture messaging still doesn't work.
Hi Micah, Picture messaging should work even without a data booster... so something must be wrong. Have you checked if the APN settings are exactly as described here? http://help.koodomobile.com/plans-add-ons-data-and-other-services/data-basics/how-do-i-setup-data-on-my-non-koodo-phone
There is no way to see APN settings in iOS 7
There is with unlocked phones. I suggest that you reset your network settings (settings > general > reset > reset network settings). You'll lose any saved WiFi passwords and profiles, but all your other data will be kept. The phone will reboot.
